[Gdal-dev] Error when using gdalinfo (ERROR 1: no system list, errno: 100)
Reiner R.Beck at m4com.de
Mon Nov 3 14:14:27 EST 2003
Hello List,
I try to use gdalinfo on one of the geotiff files from the geotiff
example files (located in "samples1/spot/chicago/SP27GTIF.TIF"). When
printing the corner coordinates, I get the message "ERROR 1: no system
list, errno: 100" (see below for the complete output). This happens for
other valid geotiff files as well.
Is this the normal behaviour or what is wrong here?
BTW, a "listgeo" on the same file prints the corner coordinates
correctly ...
Here's some version info:
- gdal was build with the following configure options: "./configure
--without-jasper"
 > gdalinfo --version
GDAL 1.1.9.0, released 2003/06/27
 > proj
Rel. 4.4.7, 31 March 2003
GeoTIFF: 1.2.0
TIFF: 3.6.0
Cheers
Reiner
--- snip begin ---
 > gdalinfo SP27GTIF.TIF
Driver: GTiff/GeoTIFF
Size is 699, 929
Coordinate System is:
PROJCS["NAD27 / Illinois East",
    GEOGCS["NAD27",
        DATUM["North_American_Datum_1927",
            SPHEROID["Clarke 1866",6378206.4,294.9786982138982,
                AUTHORITY["EPSG","7008"]],
            AUTHORITY["EPSG","6267"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4267"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",36.66666666666666],
    PARAMETER["central_meridian",-88.33333333333333],
    PARAMETER["scale_factor",0.999975],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["US survey foot",0.3048006096012192,
        AUTHORITY["EPSG","9003"]],
    AUTHORITY["EPSG","26771"]]
Origin = (681480.000000,1913050.000000)
Pixel Size = (32.800000,-32.800000)
Corner Coordinates:
Upper Left  (  681480.000, 1913050.000)
Lower Left  (  681480.000, 1882578.800)
Upper Right (  704407.200, 1913050.000)
Lower Right (  704407.200, 1882578.800)
Center      (  692943.600, 1897814.400)
Band 1 Block=699x11 Type=Byte, ColorInterp=Gray
--- snip end ---
