[Gdal-dev] Bug in BMP driver?
Winkler, Roland
RWinkler at DEFiNiENS.com
Tue Nov 4 08:39:44 EST 2003
I have problems reading a 32 bit RGB Windows Bitmap (type BMPC_RGB). I
changed the ::IReadblock for 32 bit bitmaps and it worked afterwards:
CPLErr BMPRasterBand::IReadBlock::IReadBlock()
old:
if ( poGDS->sInfoHeader.iBitCount == 24 ||
poGDS->sInfoHeader.iBitCount == 32 )
for ( i = 0, j = 0; i < nBlockXSize; i++ )
// Colour triplets in BMP file organized in reverse order:
// blue, green, red
((GByte *) pImage)[i] = pabyScan[j + iBytesPerPixel - nBand];
j += iBytesPerPixel;
new:
if ( poGDS->sInfoHeader.iBitCount == 24 )
.. like before
else if ( poGDS->sInfoHeader.iBitCount == 32 )
((GByte *) pImage)[i] = pabyScan[j + iBytesPerPixel - nBand -
1];
the reason for the -1 in the 32 bit case:
in 24 bit case for each pixel the array pabyScan looks like [BGR] pImage is
assigned [RGB]
the implementation for 32 implies that the order of pabyScan is [ABGR], but
I think it should be [BGRA].
I'm not quite sure about it, because I have only one 32 bit bitmap and I
couldn't produce another example.
Has anybody else problems with 32 bit .bmp's, or is my .bmp corrupt?
Thanks
Roland
_________________________________
Roland Winkler,
Software Development
Definiens AG
Trappentreustrasse 1
D-80339 Munich
Fon: +49 (0)89 - 231180 - 56
Fax: +49 (0)89 - 231180 - 90
mailto:rwinkler at definiens.com <mailto:rwinkler at definiens.com>
http://www.definiens.com <http://www.definiens.com/>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20031104/33bc28bc/attachment.html
