R: [Gdal-dev] gdal in debian
Andrey Kiselev dron at ak4719.spb.edu
Wed Nov 5 16:14:12 EST 2003
On Wed, Nov 05, 2003 at 10:54:19AM +0100, Amici Alessandro wrote:
> Andrey, on arm and powerpc we get the following error into the hdf4 driver:
> make[3]: Entering directory `/build/buildd/gdal-1.2+cvs.031016/frmts/hdf4'
> /bin/sh ../../libtool --mode=compile g++ -I../../port -I../../gcore
> -I../../ogr -I/usr/include/hdf -Wall  -O2   -c -o ../o/hdf4dataset.o
> hdf4dataset.cpp
>  g++ -I../../port -I../../gcore -I../../ogr -I/usr/include/hdf -Wall -O2 -c
> hdf4dataset.cpp  -fPIC -DPIC -o ../o/.libs/hdf4dataset.o
> hdf4dataset.cpp: In member function `char**
>    HDF4Dataset::TranslateHDF4Attributes(long int, long int, char*, long int,
>    long int, char**)':
> hdf4dataset.cpp:763: error: invalid conversion from `int8*' to `const char*'
> hdf4dataset.cpp:766: error: invalid conversion from `int8*' to `const char*'
> make[3]: *** [../o/hdf4dataset.o] Error 1
> if you so wish i can file a bug report.
Yes, it will be good to fill the report (put dron at remotesensing.org
in address field). Do you speaking about 1.1.9 release or about CVS
snapshot?
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
