[Gdal-dev] OGR geometry transform memory issue
Mon Nov 10 09:45:57 EST 2003
Brian Marchand wrote:
> Hello,
> I found a crash in the OGR code due to freeing up the target
> OGRSpatialReference object that is created by the
> OGRCoordinateTransformation class when calling
> OGRCreateCoordinateTransformation. The crash occurred when the geometry
> transform method assigned the “target” OGRSpatialReference object that
> was created by the transformation object. When I destroyed the
> transformation object the OGRProj4CT destructor destroyed the
> OGRSpatialReference and the geometry was then pointing to deleted
> memory. The next time the geometry’s SRS object was used I would get a
> crash.
> It seems like the problem could be fixed two ways. Either the geometry
> clones the OGRSpatialReference object instead of assigning it, or the
> OGRCoordinateTransformation object looks at the reference count of the
> target OGRSpatialReference object before deleting it.
Brian,
The correct approach would be to decrement and check the reference count
before destroying.  Cloning the coordinate system would be very expensive.
I will implement this in CVS and add a test to the testsuite.
Best regards,
