[Gdal-dev] Pymod versions
Norman Vine nhv at cape.com
Thu Nov 13 19:37:59 EST 2003
Tyler Mitchell writes:
> > I assume you mean python 2.3 vs python 2.2, right?  I am pretty sure that
> > the OpenEV_FW 1.6.2 distribution is using Python 2.2.  However, the
> python
> > scripts themselves are generally ok with any python 2.x version.  If you
> > were to build stuff yourself it should be possible to do it with python
> 2.3
> > and then you could use python 2.3 features if you wanted.
> You're right, Python 2.3 and 2.3.  I just got 2.3 removed from my system
> and now I'm working okay again.  I think that I couldn't import gdal into
> 2.3.  I'll see if I can reproduce it.
GDAL pymod appears to work fine with Python2.3 when compiled
against 2.3 .  Cygwin Python2.3 has a problem importing a GDAL
compiled with 2.2. Don't know about other OS
HTH
Norman
