[Gdal-dev] error and fix for s57 breakage
Thom DeCarlo T.R.DeCarlo at larc.nasa.gov
Fri Nov 14 15:06:24 EST 2003
The same change is needed in the makefile.vc file.
>Vincent Schut gdal-dev at remotesensing.org
>Fri, 14 Nov 2003 12:12:40 +0100
>Frank and others,
>due to an error in gdal/ogr/ogrsf_frmts/s57/GNUMakefile gdal-cvs won't
>compile if ogr is enabled. The solution is to add 's57featuredefns.o'
>to the 'OBJ =' line in the GNUMakefile in the s57 directory (and
>probably similar addition to the Makefile?).
>Cheers,
>Vincent.
Thom DeCarlo
Sr. S/W Eng, VisSim
Team ConITS - AvSP - LaRC - NASA
