[Gdal-dev] JasPer UUID package updated
Howard butler hobu at iastate.edu
Sat Nov 15 17:23:05 EST 2003
Hello,
I build the new Jasper package using Microsoft VC++ project this morning (I
renamed the jas_config2.h in the include directory to jas_config.h ... I
don't know if this was the right thing to do).
After building, I've been trying to link it into GDAL, but I'm getting a
bunch of errors that look like:
LIBC.lib(crt0dat.obj) : error LNK2005: _exit already defined in
MSVCRT.lib(MSVCR
T.dll)
LIBC.lib(crt0init.obj) : error LNK2005: ___xc_z already defined in
MSVCRT.lib(ci
nitexe.obj)
LIBC.lib(crt0init.obj) : error LNK2005: ___xc_a already defined in
MSVCRT.lib(ci
nitexe.obj)
LIBC.lib(crt0init.obj) : error LNK2005: ___xi_z already defined in
MSVCRT.lib(ci
nitexe.obj)
LIBC.lib(crt0init.obj) : error LNK2005: ___xi_a already defined in
MSVCRT.lib(ci
nitexe.obj)
LIBC.lib(mbctype.obj) : error LNK2005: __getmbcp already defined in
MSVCRT.lib(M
SVCRT.dll)
MSVCRT.lib(MSVCRT.dll) : error LNK2005: __strdup already defined in
LIBC.lib(str
dup.obj)
If I remove the Jasper stuff from the GDAL nmake.opt file, GDAL builds fine.
Did I build Jasper incorrectly?
Howard
At 01:51 PM 11/15/2003, you wrote:
> > JPEG2000 driver with support for georeferencing
>Hmmm - adding an external .wld file seems to work also (at least for
>Kakadu within the context of MMS...)
>Chris
>-----Original Message-----
>From:   Andrey Kiselev [mailto:dron at ak4719.spb.edu]
>Sent:   Sat 11/15/2003 12:50 AM
>To:     gdal-dev at remotesensing.org
>Cc:
>Subject:        [Gdal-dev] JasPer UUID package updated
>Hi, folks,
>JasPer UUID package (required to build JPEG2000 driver with support for
>georeferencing) now updated to the new upstream release 1.700.5.
>New gzipped tarball available here:
>  ftp://ftp.remotesensing.org/gdal/jasper-1.700.5.uuid.tar.gz
>                                                 Best regards,
>                                                 Andrey
>Andrey V. Kiselev
>Home phone:  +7 812 5274898  ICQ# 26871517
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at remotesensing.org
>http://remotesensing.org/mailman/listinfo/gdal-dev
