[Gdal-dev] A change on gdal building dir?
Vincent Schut schut at sarvision.com
Mon Nov 17 09:22:24 EST 2003
Luis,
gdal changed, but OpenEV has not yet adapted it's build script. if I
remember well you can just make a symbolic link: 'ln -s gcore core'
which would trick openev to compile.
Cheers,
Vincent.
On 2003.11.17 15:21, Luis W. Sevilla wrote:
> Hi again,
>    I'm trying to build OpenEV+gdal from sources.  After building and
> installing (make; make install), when configuring OpenEV for building
> I've got folowing error:
> luisw at Aplicgraf1:/source/python/openev> ./configure --with-gdal=/
> source/c/gdal
> loading cache ./config.cache
> checking for gcc... gcc
> checking whether the C compiler (gcc  ) works... yes
> checking whether the C compiler (gcc  ) is a cross-compiler... no
> Using requested GDAL_HOME of /source/c/gdal
> configure: error: 'Unable to find /source/c/gdal/core directory, are
> you sure a
> regular GDAL build tree can be found at /source/c/gdal?'
> There's a gcore directory under my GDAL build tree, but no core
> directory at all. I's a change on gdal building dir or am I doing
> something wrong ?
>    Luis
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
