[Gdal-dev] Anything changed on reading Geo-Information from G eoTiff?
Winkler, Roland RWinkler at DEFiNiENS.com
Tue Nov 18 11:03:58 EST 2003
I attched the output of gdalinfo and also the .tfw file of the tiff.
Unfortunately I don't know the "listgeo"-tool.
I could also provide the image, but it's 75MB after compressing still
20MB, pretty to much for putting it into bugzilla. After creating a
subset with erdas or even with the older gdal version this problem
is vanished.
If you are still interested in the image I could put it on our ftp-server
or burn it on a CD and send this CD via mail.
best regards
roland
> -----Original Message-----
> From: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Sent: Dienstag, 18. November 2003 16:11
> To: gdal-dev at remotesensing.org
> Subject: Re: [Gdal-dev] Anything changed on reading
> Geo-Information from GeoTiff?
> Winkler, Roland wrote:
> > Hi,
> > I have some problems with a geo-tiff. The x-coordinate I
> receive with
> > GDALGetGeoTransform() has the wrong sign. It's positive,
> but it should
> > be negativ. With an older version of gdal (1.1.7) I get the correct
> > value.
> > Is anything changed on reading the Geo-Information?
> Roland,
> Can you provide the file(set) in question for further
> investigation? Altnernatively, showing the output from
> "gdalinfo" and "listgeo" would be helpful in diagnosing the problem.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial
> Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal> -dev
Driver: GTiff/GeoTIFF
Size is 5000, 5000
Coordinate System is `'
Origin = (57499.500000,240000.000000)
Pixel Size = (0.500000,-0.500000)
Corner Coordinates:
Upper Left  (   57499.500,  240000.000)
Lower Left  (   57499.500,  237500.000)
Upper Right (   59999.500,  240000.000)
Lower Right (   59999.500,  237500.000)
Center      (   58749.500,  238750.000)
Band 1 Block=5000x1 Type=Byte, ColorInterp=Red
Band 2 Block=5000x1 Type=Byte, ColorInterp=Green
Band 3 Block=5000x1 Type=Byte, ColorInterp=Blue
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20031118/ee49a19d/10245001.obj
