[Gdal-dev] gdal_translate: using "-b" switch
Matt Wilkie matt.wilkie at gov.yk.ca
Tue Nov 18 13:03:20 EST 2003
>>however when I use multiple -b's the output image only has one band.
> No, your syntax is right, but your GDAL distribution is wrong :-)
erkh. Obviously I should be paying more attention to the changelog.
Thanks Andrey.
Webmaster: It would be a good idea to note which gdal version number the
docs page refers to.
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
