[Gdal-dev] windows ogr2ogr including OCI
CARLOS GARCIA cgarcia at cable.net.co
Thu Nov 27 11:36:21 EST 2003
Please use this http://www.sigtech-co.com/gdalOCI.zip
This was compiled with oci support. Note that the oracle client must be
installed prior to execute.
Good luck
Carlos
-----Mensaje original-----
De: gdal-dev-admin at remotesensing.org
[mailto:gdal-dev-admin at remotesensing.org] En nombre de Norman Vine
Enviado el: Jueves, 27 de Noviembre de 2003 10:09 a.m.
Para: gdal-dev at remotesensing.org
Asunto: RE: [Gdal-dev] windows ogr2ogr including OCI
Julien Demaria writes:
>            => I easy compiled GDAL with cygwin DLL but it failed with
> -mno-cygwin when I tried...
I routinely compile GDAL with the MingW standalone compiler from within
a Cygwin shell.  AFAIK others are succesfully doing this from within a
MSYS shell.
The only thing I haven't managed to get working yet is Python support
but I haven't tried real hard because I do most of my command line work
in a Cygwin shell where I use a Cygwin compiled GDAL and Python.
Cheers
Norman
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
