[Gdal-dev] ogr2ogr issue with postgis
Fri Nov 28 13:39:24 EST 2003
Tommie M. Jones wrote:
> Hello,
> I am trying to use ogr2ogr on postgres7.4 and postgis. It converts tiger
> data to postgis. My command line looks like the following
> /usr/local/gz-packages/openev_FW/bin/ogr2ogr -f PostgreSQL PG:dbname=billboard TGR13001 -lco LAUNDER=YES
> I do a \dt and all the tables list.
> However when I try and look at an individual table the following happens.
> billboard=# select * from ZipPlus4
> billboard-# ;
> ERROR:  relation "zipplus4" does not exist
> billboard=# \d zipplus4
> Did not find any relation named "zipplus4".
Tommie,
The problem is related to use of mixed case in table names.  You need to
quote mixed case table names.  I think something like:
  select * from "ZipPlus4";
I thought I had changed the code to "launder" table names as well as
field names.  Apparently I did not.
Best regards,
