[Gdal-dev] `MULTILINESTRING' not supported
Thu Oct 2 13:41:34 EDT 2003
Tyler Mitchell wrote:
> I'm working in Mapserver with a DGN file (and trying to remember the
> lessons I learned last time :).
> I'm getting this error, which appears related to ogr:
> msDrawMap(): Image handling error. Failed to draw layer named 'dgntest'.
> ogrGeomLine(): OGR error. OGRGeometry type `MULTILINESTRING' not supported.
> Are you familiar with this problem or is it a problem at my end or is it a
> bug.  I've attached the renegade dgn file.
> Here is my  layer def'n in mapserver.  Any ideas?
Tyler,
This is a MapServer/OGRLink issue.  If you file a bug for it in MapServer
bugzilla and assign it to me, I will try to fix it up.  I don't think mapserver
has a concept of multilinestrings, so I am not exactly sure what I will do with
it.
Best regards,
