R: [Gdal-dev] Compile latest cvs under Solaris 2.8
Oliver Wesp wesp at gdv.com
Wed Oct 8 06:58:47 EDT 2003
Thanks for your response. I did what you suggested without any effect.
best regards
Oliver
Amici Alessandro wrote:
>Oliver,
>>I'm trying to build latest cvs (gdal-cvs-031007) on my solaris 2.8 box
>>which gives me the following error:
>>ld: warning: file
>>/usr/local/lib/gcc-lib/sparc-sun-solaris2.8/3.2.2/../../../libstdc++.so:
>>linked to /usr/local/lib/./libstdc++.so: attempted multiple inclusion of
>>file
>this looks like a warning, and hopefully it is innocous.
>>Undefined                       first referenced
>> symbol                             in file
>>OCICollAppend                       ../.libs/libgdal.so
>>OCIErrorGet                         ../.libs/libgdal.so
>>ld: fatal: Symbol referencing errors. No output written to .libs/ogrinfo
>>collect2: ld returned 1 exit status
>the gdal build system is not 100% resistant to changes in the configure
>command line options without a 'make clean' in between.
>is it possible that you switched on/off the support for oracle without
>doing cleaning the build dirs in between? (i cannot test with oracle,
>but doing that with jpeg produces errors similar to what you are seeing)
>if so please try to 'make distclean', then reconfigure and rebuild.
>cheers,
>alessandro
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at remotesensing.org
>http://remotesensing.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20031008/21097466/attachment.html
