[Gdal-dev] RE: Kakadu georeferencing
Chris G. Nicholas cgn at globexplorer.com
Tue Oct 14 13:10:48 EDT 2003
Just wondering if the Kakadu driver will properly pick up an external ".wld" file in the context of Minn Map Server.  We have a bunch of shtuff from before GeoJP2 was invented...
pogo-> more S-18-00.wld
28.500000000000000
0.000000000000000
0.000000000000000
28.500000000000000
116023.500000000000000
997.500000000000000
pogo->
pogo-> gdalinfo S-18-00.jpc
Driver: JP2KAK/JPEG-2000 (based on Kakadu)
Size is 26946, 19489
Coordinate System is `'
Origin = (0.000000,0.000000)
Pixel Size = (1.000000,1.000000)
Corner Coordinates:
Upper Left  (   0.0000000,   0.0000000)
Lower Left  (       0.000,   19489.000)
Upper Right (   26946.000,       0.000)
Lower Right (   26946.000,   19489.000)
Center      (   13473.000,    9744.500)
Band 1 Block=512x128 Type=Byte, ColorInterp=Gray
  Overviews: 13473x9745, 6737x4873, 3369x2437, 1685x1219, 843x610, 422x305, 211x
153
Band 2 Block=512x128 Type=Byte, ColorInterp=Gray
153
Band 3 Block=512x128 Type=Byte, ColorInterp=Gray
153
thanks!
Chris Nicholas
GlobeXplorer
