R: [Gdal-dev] Re: Compile Error
Wed Oct 15 11:52:37 EDT 2003
Paul Kelly wrote:
> On Wed, 15 Oct 2003, Amici Alessandro wrote:
>>Paul,
>>your problem should be fixed in cvs now. would you double check and
>>report how it goes?
> Yes, working fine now. Below are a few other simple changes I had to make
> to get it to compile. The new shared library is called libgdal.so.2.9.
Paul,
C++ style comments now fixed in CVS.  The contour.cpp should be fixed in my
next commit of contour.cpp which is being substantially rewritten to use
a more efficient algorithm.
Best regards,
