[Gdal-dev] Sinusoidal projection for MODIS images with OGR
Andrey Kiselev dron at ak4719.spb.edu
Thu Oct 16 02:58:14 EDT 2003
On Wed, Oct 15, 2003 at 06:13:10PM +0200, Markus Neteler wrote:
> On Tue, Oct 14, 2003 at 01:41:31PM -0400, Ben Discoe wrote:
> > Well, if the images are in a normal sinusoidal (SIN), then we don't
> > need the MODIS reproject tool at all, we can just use GDAL :-)
> Mhhh, for me it doesn't work (yesterday's CVS version). Trying on
> "MODIS/Terra Land Surface Temperature/Emissivity Daily L3 Global 1km SIN Grid":
> gdalinfo MOD11A1.A2000055.h18v04.004.2002355023354.hdf
> Driver: HDF4/Hierarchical Data Format Release 4
Markus,
This is not supported directly by the HDF driver yet. I'm working to
improve the driver as I promised before. I think Ben uses world file to
specify corner coordinates and -a_srs option to set an input projection
for his JPEGs. But HDF driver doesn't support world files, so individual
subdatasets should be converted in other format (TIFF) if you want to do
so.
						Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
