[Gdal-dev] RE: Kakadu, MMS
Chris G. Nicholas cgn at globexplorer.com
Thu Oct 16 16:13:49 EDT 2003
With lots of help from Frank, got it to work (yeah!)
had to:
a) rebuild everything with Tiff 3.6
b) use latest/greatest GDAL from CVS
but very well worth the effort - extracting a patch from a huge image in Kakadu only takes a few seconds.
thanks again for great software.
Chris
-----Original Message-----
Sent:	Wed 10/15/2003 11:27 PM
To:	gdal-dev at remotesensing.org
Cc:
Subject:	[Gdal-dev] RE: Kakadu, MMS
I have a bunch of images that look fine in kdu_show, but when I try to make MMS images out of them with GDAL, am getting just blank images with the attached MMS  .map file; tried with and without the "EXTENTS" tag...
gdalinfo sees them just fine, and gdaltranslate works on them too...
hmmmm....comments/suggestions/?? welcomed...
Chris
[cgn at localhost ecuador]$ more mosaic_08_28_2003_ecuador.wld
.0021949
0
0
-.0020833
-91.388395
10.00000
gdalinfo mosaic_08_28_2003_ecuador.jpc
Driver: JP2KAK/JPEG-2000 (based on Kakadu)
Size is 9748, 9600
Coordinate System is `'
Origin = (0.000000,0.000000)
Pixel Size = (1.000000,1.000000)
Corner Coordinates:
Upper Left  (   0.0000000,   0.0000000)
Lower Left  (       0.000,    9600.000)
Upper Right (    9748.000,       0.000)
Lower Right (    9748.000,    9600.000)
Center      (    4874.000,    4800.000)
Band 1 Block=512x128 Type=Byte, ColorInterp=Gray
  Overviews: 4874x4800, 2437x2400, 1219x1200, 610x600, 305x300, 153x150, 77x75
Band 2 Block=512x128 Type=Byte, ColorInterp=Gray
Band 3 Block=512x128 Type=Byte, ColorInterp=Gray
[cgn at localhost ecuador]$ gdalinfo r309.jp2
Size is 4800, 8400
Corner Coordinates:
Lower Left  (       0.000,    8400.000)
Upper Right (    4800.000,       0.000)
Lower Right (    4800.000,    8400.000)
Center      (    2400.000,    4200.000)
  Overviews: 2400x4200, 1200x2100, 600x1050, 300x525, 150x263, 75x132
