[Gdal-dev] Windows OpenEV HDF PB
Julien Demaria dem at acri-st.fr
Mon Sep 1 05:23:10 EDT 2003
One of the files who crash my windows openev 1.6.2 can be downloaded here :
ftp.fr-acri.com
user : openev
pass : venepo
filename : S19981822003212.L3m_MC_CHLO.hdf
Thanks in advance for debugging,
All the best,
Julien
At 14:49 29/08/2003 -0400, you wrote:
>Julien Demaria wrote:
>>Hello,
>>I try GDAL today with OpenEV_FW under Windows (OpenEV_FW version 1.6.2)
>>and Linux (OpenEV_FW version 1.5.4) platforms.
>>I have problems with this HDF4 file only with the Windows version (1.6.2) :
>>[] /users/dem/tmp/openev_FW/bin > gdalinfo
>>/obe-temp/dem/S19981822003212.L3m_MC_CHLO.hdf
>>Driver: HDF4Image/HDF4 Dataset
>>Size is 4096, 2048
>>Coordinate System is `'
>>Origin = (0.000000,0.000000)
>>Pixel Size = (1.000000,1.000000)
>>Corner Coordinates:
>>Upper Left  (   0.0000000,   0.0000000)
>>Lower Left  (       0.000,    2048.000)
>>Upper Right (    4096.000,       0.000)
>>Lower Right (    4096.000,    2048.000)
>>Center      (    2048.000,    1024.000)
>>Band 1 Block=4096x1 Type=Byte, ColorInterp=Gray
>>under linux all works very well, but on Windows when I try to import or
>>open the file python.exe fails (I have a Windows popup with "cannot read
>>memory at ...") and all OpenEV is closed...
>>Maybe it's a bug between 1.5.4 and 1.6.2 version or a GDAL HDF bug under
>>Windows ?
>Julien,
>It could be either of those.  Would it be possible to make the file available
>somewhere for Andrey or I to try out?
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at remotesensing.org
>http://remotesensing.org/mailman/listinfo/gdal-dev
