[Gdal-dev] A conceptual question about inner join.
Jean. jeanhri4 at ifrance.com
Tue Sep 2 08:56:23 EDT 2003
I want to write a custom OGR driver to access data organized as follow
(the storage is specific) :
1- PointTable
ID(as long) - Point (WKB) - Comment(As text)
2- PathTable
A Path is composed with PointTable.
PathID(as long) - PointID(as long foreign key) - Comment(As text).
An OGRFeature with a geometry of type point is perfect for the first
table.
However, the second table raises a problem. I don't know how to
represent a join (Path-Point) with an OGR Feature.
I'm not sure that the OpenGIS simple feature specification propose a way
to represent this case. The Path Table contains a geometry through the
PointTable and not itself through a column.
What is the best way to manipulate through OGR a feature composed with
list of feature?
Thanks in advance for your answers,
Jean.
_____________________________________________________________________
MSN Messenger, nouvelle version ! Personnalisez vos messages, jouez en
ligne et communiquez en temps réel par vidéo! http://ifrance.com/_reloc/m
