[Gdal-dev] OLEDBProvider
Tue Sep 2 15:06:21 EDT 2003
jeanhri4 wrote:
> I have tested successfully sfcDump on an msJet database containing a
> GEOMETRY_COLUMNS table as described in “Open GIS Simple feature
> Specification”.
> I would want to know if any program is provided with OGR to create
> OGRFeature in such a msJet database. Indeed, OGR2OGR is only able to
> create OGRFeature in the following format :
> - "ESRI Shapefile"
> - "TIGER"
> - "MapInfo File"
> - "DGN"
> - "GML".
Jean,
The short answer is that I have not done any work on loading tables
via the OLE DB interface.  My work so far has been providing read-only
OLE DB providers, and client side code to read from them.
Best regards,
