[Gdal-dev] GNU make build system update
Tue Sep 2 22:35:01 EDT 2003
Alessandro Amici wrote:
> oops! i just hit what might be a problem!
> On Wednesday 03 September 2003 00:14, Alessandro Amici wrote:
>>furthermore a 200k patch to aclocal.m4 is needed!
> the aclocal.m4 patch appear to need autoconf 2.50+, but as far as i can say
> gdal is still using autocon 2.13, so there are various alternatives:
> - gdal can switch to autoconf 2.50+ (Frank?)
> - i can look for an erlier version of libtool (i have 1.5.0a)
> - i can try to port the aclocal.m4 to the 2.13
> the libtool merge is already on held :(
Alessandro,
I suppose we should upgrade. I see I have autoconf 2.53 here on my redhat
system, so something around that version should be fine.
Best regards,
