[Gdal-dev] Oracle OGR Segmentation Fault
Wim Blanken w.blanken at geon.nl
Thu Sep 4 06:10:01 EDT 2003
Hello List,
I am experimenting with ogr in combination with oracle and having the following problem.
Using ogrinfo with layers that have been loaded using ogr2ogr is not a problem but existing layers (not loaded with ogr2ogr) are producing segmentation faults. I noticed that the ogr2ogr layers have an OGR_FID column and that the other layers not. Is this the problem. Is there a solutions to this problem?
Sincerely,
Wim Blanken
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20030904/3e132998/attachment.html
