[Gdal-dev] ogr2ogr on Red Hat Advanced Server 2.1 vs. Red Hat 9
Doug_Newcomb at fws.gov Doug_Newcomb at fws.gov
Thu Sep 4 10:03:35 EDT 2003
Frank,
>Doug,
>I don't know why this failing, expecially with the error message you are
seeing.
>If the issue where create permissions for the shapefile, I would expect
nothing
>to be created.  It might be helpful to set "CPL_DEBUG=ON" in your
environment
>to get additional information.  Also, if you can run things under valgrind
that
>might provide some useful information.
I'll try to get you more info .  I've never tried either method, but now is
a good time to start.
>I would appreciate anything you can do to narrow down this problem to
something
>I might be able to reproduce and debug.
>PS. You have some nice systems!
Thanks! I try to buy to last:-).  I put the hardware specs in to indicate
it was not likely a hardware resource issue.
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
