[Gdal-dev] Windows OpenEV HDF PB
Julien Demaria dem at acri-st.fr
Fri Sep 5 11:57:55 EDT 2003
I've just tested the problematic file with Windows OpenEV_FW version 1.5.4
and... it works fine !
If this can help you...
Regards,
Julien
At 16:23 29/08/2003 +0200, you wrote:
>Hello,
>I try GDAL today with OpenEV_FW under Windows (OpenEV_FW version 1.6.2)
>and Linux (OpenEV_FW version 1.5.4) platforms.
>I have problems with this HDF4 file only with the Windows version (1.6.2) :
>[] /users/dem/tmp/openev_FW/bin > gdalinfo
>/obe-temp/dem/S19981822003212.L3m_MC_CHLO.hdf
>Driver: HDF4Image/HDF4 Dataset
>Size is 4096, 2048
>Coordinate System is `'
>Origin = (0.000000,0.000000)
>Pixel Size = (1.000000,1.000000)
>Corner Coordinates:
>Upper Left  (   0.0000000,   0.0000000)
>Lower Left  (       0.000,    2048.000)
>Upper Right (    4096.000,       0.000)
>Lower Right (    4096.000,    2048.000)
>Center      (    2048.000,    1024.000)
>Band 1 Block=4096x1 Type=Byte, ColorInterp=Gray
>under linux all works very well, but on Windows when I try to import or
>open the file python.exe fails (I have a Windows popup with "cannot read
>memory at ...") and all OpenEV is closed...
>Maybe it's a bug between 1.5.4 and 1.6.2 version or a GDAL HDF bug under
>Windows ?
>Thanks in advance for help,
>Julien
