[Gdal-dev] GNU make build system update
Alessandro Amici alexamici at tiscali.it
Fri Sep 5 18:28:52 EDT 2003
folks,
> people with non-linux, non-windows platforms are invited to give the new
> build system a spin and report the problems they find.
i could try libtool support on a couple more targets:
cygwin -> only the static library are produced by libtool and i get a strange
		warning about possibly unresolved symbols (?)
mingw -> same as cygwin
cross-compile for mingw from linux -> apparently same as mingw
any win32 guru can help me on those?
> note that a few contrib libs are yet not supported, i.e. libgif.
> libtiff and libgeotiff are working thou.
as far as i coulf test the internal version of libpng, libgif and libjpeg now
work. i'm not sure if all version of GNU make will like the rule i used to
make them work thou.
as of now, the only major piece of gdal not yet ported to the libtool build is
the python module. i'll be working on that.
cheers,
alessandro
