[Gdal-dev] Rotate an image
Mon Sep 15 17:22:08 EDT 2003
Geographic Wizard wrote:
> Hello, all.
> What would be the best way to rotate an image with GDAL / Warp?
> Do GeoTransform[ 2 ] and GeoTransform[ 4 ] have any effect on RasterIO ?
> and are they related to rotation of an image?
Steve,
The geotransform[2] and [4] are honoured by the georeferencing based warper
so you could construct an input image with a world file with appropriate
rotational coefficients, and then use gdalwarp to "undo" the rotation.
The geotransform does *not* have any effect on raw rasterio calls.
Best regards,
