[Gdal-dev] GDALWARP Question
Thu Sep 18 23:30:51 EDT 2003
Reinaldo Escada Chohfi wrote:
> Hi GDAL Users,
> I am planning to use the gdalwarp utility to
> geo-reference a number of images in batch.
> I would like to know before hand if it can be
> utilized to warp (rectify) unprojected images.
> That is, can it input raw images with GCPs
> and output geo-referenced rectified (warped)
> Geotiff images, given that it is also provided
> proj, zone, ellps, etc?
> Or it can only be used to reproject and warp
> images that have already been rectified and are
> geometrically correct in a particular projection?
Reinaldo,
First, I would advise you to use gdalwarptest, the new generation
warper.
Second, yes, it can rectify raw images, but it can be a bit tricky
currently to supply the GCPs.  Also, currently only polynomial warps
are supported when operating from GCPs, and only up to 3rd order.
Best regards,
