[Gdal-dev] gdal_translate can now add GCPs to image, gdalwarptest renamed
Fri Sep 19 15:30:37 EDT 2003
Folks,
I have modified gdal_translate to include a -gcp option for adding
GCPs to an image.
For instance, the following would add 4 GCPs that are sufficient to
rotate an image during the translation process.
gdal_translate -gcp 0 0 100 0 -gcp 512 0 100 100 -gcp 0 512 0 0 -gcp 512 512 0 100 ~/openev/utm.tif out.tif
Then you could use gdalwarp to warp it.
Also, I have renamed gdalwarptest to gdalwarp (the new algorithm is now
the primary warper), and gdalwarp to gdalwarpsimple.  Only gdalwarp is
built and installed by default.
Best regards,
