[Gdal-dev] Running gdal_merge.py
Reinaldo Escada Chohfi rec at geodesign.com.br
Fri Sep 19 18:30:50 EDT 2003
Hello,
I unziped the openev_fw_1.6.2.zip and made the required change
in the setfw.bat file.
I can run Openev and all the gdal utilities.
However, the gdal_merge.py module code opens in the MS Notepad
when I try to run it.  I see that the icon of the modules are associated
with the Notepad.
I do not know anything about Python.  I've heard of it but never
used it before.
What program do I need to associated the module with in order to
run it, or what is needed to do to run it on Win2k?
Any suggestion is welcomed!
Thanks,
Reinaldo
