[Gdal-dev] gdal_translate can now add GCPs to image, gdalwarptest renamed
Fri Sep 19 18:28:37 EDT 2003
Reinaldo Escada Chohfi wrote:
> Franks,
> This is good news. It should help a lot. Thanks.
> I noticed that gdalwarptest has a few more parameters than the
> gdalwarp, now gdalwarpsimple.  I could not find a description
> of the additional parameters.
Reinaldo,
I will work on documenting the additional capabilities.
> I've been experimenting gdal with the openev_fw_1.6.2 pre-built
> for Win. Are you going to build a new openev_fw with the new
> gdal_translate?
Not for a week or two I don't imagine.
Best regards,
