[Gdal-dev] Running gdal_merge.py
Reinaldo Escada Chohfi rec at geodesign.com.br
Fri Sep 19 22:49:13 EDT 2003
Sean,
Thanks for the help. I did not have to download python because
it's already within openev_fw.
I got it working and the results look fine.  I did not have my paths right.
I have to study a bit on python and gdal because we can
come up with very nice tools with them.
I can write fortran, c/c++, tcl/tk and vtk codes/apps, but never
looked into python.  Also, I've had gdal on my computer for
some time and just now that decided to take a look at it.
It's very nice. Thanks Frank!
Anyway, thanks again.
Reinaldo
At 17:35 19-09-03 -0600, you wrote:
>On Friday, September 19, 2003, at 04:30  PM, Reinaldo Escada Chohfi wrote:
>>Hello,
>>I unziped the openev_fw_1.6.2.zip and made the required change
>>in the setfw.bat file.
>>I can run Openev and all the gdal utilities.
>>However, the gdal_merge.py module code opens in the MS Notepad
>>when I try to run it.  I see that the icon of the modules are associated
>>with the Notepad.
>>I do not know anything about Python.  I've heard of it but never
>>used it before.
>>What program do I need to associated the module with in order to
>>run it, or what is needed to do to run it on Win2k?
>>Any suggestion is welcomed!
>>Thanks,
>>Reinaldo
>There are other distributions of Python for Win2k, but I've only used
>this one:
>http://www.activestate.com/Products/ActivePython/
>There's a download button in the upper left of the page.  Once you've
>installed it, you can execute gdal_merge.py like
>    python gdal_merge.py
>Python is a scripting language (like Perl) and 'python' is the program that
>interprets the scripts (like the program 'perl').
>Python is powerful and very easy to learn, and is the language of
>choice for more and more GIS programming projects.  Python's home
>page
>http://www.python.org
>is not so compelling, but is the place to start for tutorials and
>language reference.
>cheers,
>Sean
>Sean Gillies
>sgillies at frii dot com
>http://www.frii.com/~sgillies
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at remotesensing.org
>http://remotesensing.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20030919/4626d956/attachment.html
