[Gdal-dev] s-57 to vrml elevation map?
Thorsten Röllich roellich at web.de
Sat Sep 20 14:31:33 EDT 2003
Hello,
I'm building a 3D model of a coastal area in Germany and try to use S-57 datasets as a source.
First I used the program SeeMyDEnc from sevencs to open my datasets and it looked fine. By picking a position on the map, the program shows the primitive DEPARE (Depth Area Group) and the corresponding depth (DRVAL1 and DRVAL2).
This seems to be enough information for modeling a (rough) topography.
So I looked for a converter, that fits my needs... (Something, that converts S-57 to VRML elevation map would be ideal)
What I found was the ogr library and the tools ogrinfo and ogr2ogr.
So I will have to write the converter myself..
The plan was to translate S-57 to GML (which is more human readable) using ogr2ogr and parse all Polygons that describe an Area and the corresponding depth.
The  translation to GML worked fine, but I could not find any depth information in the file. I tried it with many ogr2ogr options, but the 3rd dimension seems always to be lost.
Does anybody have an idea how to translate the topographic information from S-57 files to an elevation map, or how to extract the polygons and the depth of DEPARE fields?
Very thankful for any hints on this. Kindest regards / Thorsten
______________________________________________________________________________
Zwei Mal Platz 1 mit dem jeweils besten Testergebnis! WEB.DE FreeMail
und WEB.DE Club bei Stiftung Warentest! http://f.web.de/?mc=021183
