[Gdal-dev] Errors in dgnread.cpp
Sat Sep 20 20:39:38 EDT 2003
Steve Brooks wrote:
> I have found two fatal errors in dgnread.cpp the first one will cause a
> crash
> when there appears to be attributes on the tcb which inside the 'if'
> psElement->attr_bytes gets setup as a negative number which causes the
> CPLMalloc to crash.  If you would like a copy of the dgn file let me know.
> My fix was not to go inside the if( psElement->properties &
> DGNPF_ATTRIBUTES )
> if the element is a tcb.
> The next change was causing OGRLayer::GetFeature
> to not return any features.  When the DGN Index was being built the
> offset was being truncated to an invalid offest by the (unsigned char)
> cast.
> My envionment is Windows XP, Microsoft Visual Studio.Net 2003.
Steve,
I would appreciate a file to demonstrate the first problem.
The second is a very serious bug introduced in a fit of (apparently improper)
type casting fixes, and apparently breaks any random (rather than sequential)
index based element reads.
I have committed the fix for both but would still like to understand the first
issue better.
I am cc:ing the dgnlib list since it mostly effects people there, and I will
issue a new dgnlib within a couple days once I am happy with the fixes.
Best regards,
