[Gdal-dev] gdal_translation interpolation
Sat Sep 20 21:02:23 EDT 2003
Reinaldo Escada Chohfi wrote:
> gdal users,
> What's  the interpolation method used in gdal_translate
> when the size of the input dataset is changed with the
> -outsize flag?
> Are there different interpolation methods that can be used?
> If yes, what are they and the flags to use?
Reinaldo,
gdal_translate uses the resampling done by the core RasterIO() code which is
nearest neighbour (simple replication or decimation).  If you need to
control resampling you could use gdalwarp which also offers bilinear,
and two cubic algorithms.
Best regards,
