[Gdal-dev] Geosoft Grid eXchange Format and Projection support
Sat Sep 20 21:10:30 EDT 2003
N. Farah wrote:
> Hi,
> Using gdalinfo.exe on a GeoSoft Grid eXchange File (.gxf) I get the
> right information except the projection information. The projection
> string is empty.
> A check on the grid file shows that the file has a projection.
> An additional check, now using the source code, shows that the code is
> expecting the projection information to be in one line. The used .gxf
> file have the projection information in three consecutif lines.
> Probably this is the source of the problem.
> The used gxf file would be available if requested.
Noureddine,
Yes, please create a bug report in bugzilla, and attach the file and I
will see what I can do.
Best regards,
