[Gdal-dev] importing SRTM30
Andrey Kiselev dron at ak4719.spb.edu
Mon Sep 22 05:45:26 EDT 2003
On Sat, Sep 20, 2003 at 01:32:02PM -0400, Norman Vine wrote:
> > Also I have made a Python script to produce a shaded relief images
> > (algorithm was stealed from the corresponding PCI task). See that script
> > attached, those whop are using CVS tree can find it under /pymod/samples
> > directory. Script works not too fast, but it can be easily rewritten in C.
> This should be a little quicker.
Norman,
I have commited your changes along with further improvements, so the
scripts now works with a rocket speed.
					Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
