[Gdal-dev] bad make in linux
g.leej g.leej at imyourhandiman.com
Wed Sep 24 12:07:46 EDT 2003
hi..
   I'm unable to compile here in debian unstable with the following
error output and thx for any assistance you can provide:
make[2]: Entering directory `/home/neighborlee/gdal-1.1.9/frmts/bmp'
make[2]: Nothing to be done for `install-obj'.
make[2]: Leaving directory `/home/neighborlee/gdal-1.1.9/frmts/bmp'
make[2]: Entering directory `/home/neighborlee/gdal-1.1.9/frmts/gif'
g++ -c  -I../.. -I../../port -I../../gcore -I../../ogr -Wall -fPIC -O2
gifdataset.cpp -o gifdataset.o
gifdataset.cpp: In constructor
`GIFRasterBand::GIFRasterBand(GIFDataset*, int,
   SavedImage*)':
gifdataset.cpp:202: error: 'struct ExtensionBlock' has no member named '
   Function'
make[2]: *** [gifdataset.o] Error 1
make[2]: Leaving directory `/home/neighborlee/gdal-1.1.9/frmts/gif'
make[1]: *** [sub-libs] Error 1
make[1]: Leaving directory `/home/neighborlee/gdal-1.1.9/frmts'
make: *** [frmts-target] Error 2
neighborlee at Handimanstation1:~/gdal-1.1.9$
