[Gdal-dev] gdal build on solaris
Gillian Walter gillian.walter at atlantis-scientific.com
Thu Sep 25 15:03:47 EDT 2003
Configure seems to be a little bit broken for solaris.  I had to add
"-D_REENTRANT" manually to CXX_OPTFLAGS and C_OPTFLAGS in GDALmake.opt
after running configure before it would make: on our solaris machine,
localtime_r (in time.h) is bracketed by:
#if    defined(__EXTENSIONS__) || defined(_REENTRANT) ||
(_POSIX_C_SOURCE - 0 >= 199506L)
This localtime_r function is used by VSILocalTime in cpl_vsisimple.cpp
if HAVE_LOCALTIME_R is set to 1 during configure (it is on solaris).
 I'm not sure if REENTRANT was the right define to add though, or if
configure should have not set HAVE_LOCALTIME_R at all (when I added the
REENTRANT it compiled, but I don't know if it will have weird side
effects).
Gillian
