[Gdal-dev] Re: porting of gdal to (optional) libtool build finally completed
Thu Sep 25 16:09:28 EDT 2003
Alessandro Amici wrote:
> folks,
> it has taken a good two months, but i'm finally ready to announce that the
> optional libtool build is now ready for prime time :).
> Frank, what's your opinion? isn't it tempting to support all unices with just
> one set of configure-makefile rules?
> questions, comments and test report on other systems are welcome.
Alessandro,
I concur ... you can make "with libtool" the default, as --without-libtool
works to make things as they are now.  If we don't change the default, it is
unlikely the mechanism will get much testing and I would like it to be the
default for the 1.2.0 release relatively soon.
Good work!
Best regards,
