[Gdal-dev] GDALNumeric.SaveArray : Unable to access numpy arrays of typecode "@"
Gillian Walter gillian.walter at atlantis-scientific.com
Fri Sep 26 10:50:44 EDT 2003
I had the same problem.  This was Frank's response (his -DHAVE_NUMPY
solution worked for me):
This might be an issue with how GDAL is built on windows.  If GDAL doesn't
"know" how to find Numeric/arrayobject.h to get at the definitions of
the PaArray_Descr and PyArrayObject structures it just falls back to using
internal declarations for these presumably copied from an earlier version
of Python.  To the best of my knowledge the internal (out of date)
definitions
are always used on windows.
Try adding -DHAVE_NUMPY to OPTFLAGS in nmake.opt and see if things work.
The easiest way to verify you are getting system definitions of the numpy
stuff would be to add a #error directive in the "#ifndef HAVE_NUMPY"
section
of gdal/pymod/gdal_py.h.
- Gillian
Gagan Tandon wrote:
> Dear Friends,
> I am using Numeric 23.0 version and python 2.3 on a windows XP
> machine. I have build GDAL from MS VC++ and Visual Studio .net and
> installed on my machine. The GDAL version is 1.1.9.
> Basic Problem : I am trying to save a Numpy array(infact the primary
> issue is to save any 2d array (not just NUMPY) to a "TIF" file) to a
> TIF file. When I run the following commands, I get an error stating
> that it cannot access Numpy array of typecode "@"  (weird..??)
> DUMP OF PYTHON INTERPRETER.
> >>> k = Numeric.zeros((2,2),"f")
> >>> k
> array([[ 0.,  0.],
>        [ 0.,  0.]],'f')               // I have tried with array k =
> array([[1.2, 2.3], [2.5,1.7]],"f")
> >>> import gdalnumeric
> >>> gdalnumeric.SaveArray(k,"k.tif")
> ERROR 1: Unable to access numpy arrays of typecode `@' <mailto:%60@%27>.
> Traceback (most recent call last):
>   File "<stdin>", line 1, in ?
>   File "C:\GDAL\pymod\gdalnumeric.py", line 97, in SaveArray
>     return driver.CreateCopy( filename, OpenArray(src_array,prototype) )
>   File "C:\GDAL\pymod\gdal.py", line 330, in CreateCopy
>     target_ds = _gdal.GDALCreateCopy( self._o, filename, source_ds._o,
> AttributeError: 'NoneType' object has no attribute '_o'
> ---- END OF PYTHON INTERPRETER
> I am wondering whether this is a version problem with Numeric python
> or is it a problem with the building of GDAL using MS VC++ 7.0  or is
> it something else. I would be delighted if any one can give me clues
> on how to save a 2d array to a TIF file, since thats the primary problem.
> Thanks
> Gagan Tandon
> Gagan Tandon
> Research Assistant
> GIS and Remote Sensing
> Colorado State University
> Attention all artisans! Sell Diwali creations online. Register now!
> <http://g.msn.com/8HMAENIN/2734??PS=>
> _______________________________________________ Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
