[Gdal-dev] Memory leak fix for ogrdgnlayer.cpp
Mon Sep 29 10:26:03 EDT 2003
Steve Brooks wrote:
> Frank,
> Below is a memory leak fix for ogrdgnlayer.cpp, when converting
> complex linestrings from the dgn the child DGNElement (psChildElement)
> wasn't being freed after conversion to the poChildFeature.
> Steve Brooks
> $ diff clean/ogrdgnlayer.cpp modified/ogrdgnlayer.cpp
> 587c587,590
> <                   poChildFeature = ElementToFeature( psChildElement );
>  >                  DGNFreeElement( hDGN, psChildElement );
Steve,
I see your point.  Patch applied in CVS.
Thanks,
