[Gdal-dev] img format resizing
Fri Apr 2 14:50:35 EST 2004
list67 at netscape.net wrote:
> Frank,
> Here are the gdalinfo reports for the before and after resizing img files:
> gdalinfo ./beforeResize.img
> Driver: HFA/Erdas Imagine Images (.img)
> Size is 1487, 2900
> Coordinate System is:
> LOCAL_CS["Unknown",
>     UNIT["meters",1]]
> Origin = (0.000000,0.000000)
> Pixel Size = (0.00010000,0.00010000)
> Corner Coordinates:
> Upper Left  (   0.0000000,   0.0000000)
> Lower Left  (   0.0000000,   0.2900000)
> Upper Right (   0.1487000,   0.0000000)
> Lower Right (   0.1487000,   0.2900000)
> Center      (   0.0743500,   0.1450000)
> Band 1 Block=64x64 Type=Byte, ColorInterp=Undefined
> Band 2 Block=64x64 Type=Byte, ColorInterp=Undefined
> Band 3 Block=64x64 Type=Byte, ColorInterp=Undefined
> Band 4 Block=64x64 Type=Byte, ColorInterp=Undefined
Mike,
This coordinate system is indeed "upside down" to what GDAL expects.
One slightly clumsy approach to working around this is to create a
virtual file for your dataset and edit the geotransform in that.
eg.
gdal_translate -of VRT beforeResize.img beforeResize.vrt
... edit beforeResize.vrt changing the sign of the 5th # of the
     <GeoTransform> to be negative
gdalwarp beforeResize.vrt ...
Basically, gdalwarp is not setup to work with inputs in what it
considers upside coordinate systems.
Best regards,
