[Gdal-dev] GDAL Utilities Documentation
Fri Apr 2 17:58:44 EST 2004
Matt Wilkie wrote:
> #  gdal-config - Get options required to build software using GDAL[[,]]
> against GDAL.
Fixed.
> #Creating New Files > -a_srs: the EPSG bullet paragraph is repeated
Fixed.
> #General Command Line Switchces
>  --optfile file:
> Not sure where in the document this should go, but it would nice if
> there were an example showing it's use, e.g.:
--optfile is described amoung the general options, but without an
example.  In my (not so humble) opinion the example would bulk things
up distractingly at this point in the document.
> gdal_info:
>   o. Raster size (in pixel[[s]] and lines).
Fixed.
> gdal_translate:
>  -srcwin xoff yoff xsize ysize:
>     Selects a subwindow from the source image for copying. [[Corners
> given in pixel coordinates.]]
Fixed.
> gdal_warp:
>  -wo "NAME=VALUE":
>     Set a [[lot]] of warp options....
Fixed
> Suggested Changes
> --help-general:
> Why be so specific? Better to use '--help' for general help. This is how
> most linux utilities seem to work.
This only reports help on the "general" options, the options shared amoung
all programs.  The --help is intended to return the generic usage message
for the program.
> --format format-name
> Might make more sense to use '--help format-name' instead.
I would prefer not to.
> gdal_warp:
>  -rn, -rb, -rc, -rcs:
> Better to harmonize with with gdaladdo -r {nearest,average,...}
Unfortunately, I don't have the anything like the same set of options so
they aren't likely to ever be too similar.  I could change them to use
a more consistent approach but it would add little value for the disruption
at this point.
Thanks for the feedback!
Best regards,
