[Gdal-dev] Center of polygon
Daniel Morissette dmorissette at dmsolutions.ca
Mon Apr 5 18:24:35 EDT 2004
Clay, Bruce wrote:
> Is there a method within OGR to find the center of a polygon (where it
> is not part of the data set) or polyline for the purposes of centering a
> label?  If not does anyone have a method they are willing to share to
> walk through the data of a polygon / ring to determine the center?
The MITAB driver contains a function called OGRPolygonLabelPoint() in
ogr/ogrsf_fmrts/mitab/mitab_geometry.cpp that will compute a label point
  on an OGRPolygon.
The function is only local to the MITAB driver and is not part of the
public OGR API, but you can probably make a copy.
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
