[Gdal-dev] Georeferencing a tiff file
Tue Apr 6 10:47:24 EDT 2004
Romano J M Silva wrote:
> Hello all,
> I have a tiff file and I want to georeference it and save it as a
> GeoTiff to use in GDAL . Does anyone know of a tool to do that?
> Thanks,
> Romano
When you say "I want to georeference it", do you already know the georeferencing
or are you wanting to do a tie down in a GUI environment?  If you know the top
left corner and pixel spacing you can manually create a corresponding
"world file" for the file and then use gdal_translate to "apply" that
world file along with a coordinate system and produce an output file.
For instance, imagine you had a file called raw.tif with 60m x 60m pixels, and
a top left corner of 440750m E, 3751290m N in UTM 11 WGS84.  You could
georeference it by creating a world file called raw.tfw with the following
in it (six lines):
Then use this gdal_translate command to create a geotiff version with a
coordinate system.
  gdal_translate -a_srs '+proj=utm +zone=11 +datum=WGS84' raw.tif geotiff.tif
Best regards,
