[Gdal-dev] Center of polygon
Clay, Bruce bclay at ball.com
Tue Apr 6 11:02:54 EDT 2004
Daniel:
  Thanks for the tip.  All I had to do is include the mitab_geometry.h
file and the method did what I needed.
Frank:  Several of the methods in this file seem to be quite generic.
Could / should they be moved to the public ORG API.  So far I have only
used OGRPolygonLabelPoint on polygons but I will be trying it on
polylines this afternoon.
Bruce
bclay at ball.com
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org] On Behalf Of Daniel Morissette
Sent: Monday, April 05, 2004 6:25 PM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] Center of polygon
Clay, Bruce wrote:
> Is there a method within OGR to find the center of a polygon (where it
> is not part of the data set) or polyline for the purposes of centering
> a label?  If not does anyone have a method they are willing to share
> to walk through the data of a polygon / ring to determine the center?
The MITAB driver contains a function called OGRPolygonLabelPoint() in
ogr/ogrsf_fmrts/mitab/mitab_geometry.cpp that will compute a label point
  on an OGRPolygon.
The function is only local to the MITAB driver and is not part of the
public OGR API, but you can probably make a copy.
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
