[Gdal-dev] Center of polygon
Chapman, Martin MChapman at sanz.com
Tue Apr 6 14:40:17 EDT 2004
Wow, the geos code looks powerful, you should totally integrate it with
OGR.  Thanks a ton for the link!
Martin
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Tuesday, April 06, 2004 11:07 AM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] Center of polygon
Chapman, Martin wrote:
> Frank,
> What is GEOS? Can you point me to the homepage?
Martin,
Is it is a C/C++ port of the Java Topology Suite.  It can be found at:
   http://geos.refractions.net/
It is an opengis simple features geometry based geometry engine.   It is
already used by PostGIS and since it shares a geometry model (though not
the actual object instance format) with OGR I think it should be easy to
integrate it to implement a variety of complex geometry operations for
OGR.
Doing so is on my long term "todo" list.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
