RES: [Gdal-dev] Compiling GDAL
Gabriel Moricz gabriel at autofax.com.br
Wed Apr 14 10:48:46 EDT 2004
Thanks Frank...
Well....If I install it without Gif, what will happen later when I install
MapServer...
Does MapServer requires gdal with GIF???
Thanks..
Gabriel Moricz
-----Mensagem original-----
De: gdal-dev-admin at remotesensing.org
[mailto:gdal-dev-admin at remotesensing.org]Em nome de Frank Warmerdam
Enviada em: quarta-feira, 14 de abril de 2004 11:39
Para: gdal-dev at remotesensing.org
Assunto: Re: [Gdal-dev] Compiling GDAL
Gabriel Moricz wrote:
> Hello..
> I hope that this list help me...I am needing and it is a bit urgent...
> Well.....I am using gdal-1.2.0 in a Debian distribution...
> Well I made my ./configure like this:
./configure --with-libtiff=/usr/local --with-geotiff=/usr/local --with-jpeg=
> /usr --with-gif=/usr --with-pg=/usr/local/pgsql/bin/pg_config
> where libtiff, geotiff and pgsql I have downloaded the source and complied
> and installed..
> and JPEG, and GIF I used the pre-installed of the Debian via apt-get
> well the configure shows the result that I wanted but the make returns a
> error that I have no idea to how to solve it...
> The error is:
> make[2]: Entering directory `/usr/local/src/gdal-1.2.0/frmts/gif'
> /bin/sh ../../libtool --mode=compile
g++ -Wall  -O2   -I/usr -I/usr/include -I/usr -I/usr/include -I/usr/local/in
clude -I/usr/local/include   -I../../port -I../../gcore -I../../ogr -I../../
> port  -c -o ../o/gifdataset.o gifdataset.cpp
g++ -Wall -O2 -I/usr -I/usr/include -I/usr -I/usr/include -I/usr/local/inclu
de -I/usr/local/include -I../../port -I../../gcore -I../../ogr -I../../port
> -c gifdataset.cpp  -fPIC -DPIC -o ../o/.libs/gifdataset.o
> gifdataset.cpp: In method `GIFRasterBand::GIFRasterBand(GIFDataset *, int,
> SavedImage *, int)':
> gifdataset.cpp:214: `struct ExtensionBlock' has no member named `Function'
> make[2]: *** [../o/gifdataset.o] Error 1
> make[2]: Leaving directory `/usr/local/src/gdal-1.2.0/frmts/gif'
> make[1]: *** [gif-install-obj] Error 2
> make[1]: Leaving directory `/usr/local/src/gdal-1.2.0/frmts'
> make: *** [frmts-target] Error 2
Gabriel,
I believe you will just have to use the internal libgif or configure GDAL
without it.  The GDAL higher level code requires some stuff from a quite
recent version of the library ... apparently newer than what you have
installed via apt-get anyways.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
