RES: RES: RES: [Gdal-dev] Compiling GDAL
Gabriel Moricz gabriel at autofax.com.br
Wed Apr 14 11:45:29 EDT 2004
Thanks Frank...
I will use without Gif, and let gd serve Gif for MapServer...
Well...is GDAL the one whose compiles OGR???
How can I do it???is it just compile and install GDAL???
Thanks..
Gabriel Moricz
-----Mensagem original-----
De: gdal-dev-admin at remotesensing.org
[mailto:gdal-dev-admin at remotesensing.org]Em nome de Frank Warmerdam
Enviada em: quarta-feira, 14 de abril de 2004 12:25
Para: gdal-dev at remotesensing.org
Assunto: Re: RES: RES: [Gdal-dev] Compiling GDAL
Gabriel Moricz wrote:
> I did not get it...
> Well...
> I pretend to use mapserver with gd, proj, gdal, ogr, wmsclient, postgis,
> wms, wfsclient, httpd..
> Well...Do u think that I will have problems if I compile GDAL without
gif???
> Sry..I am a begginer with this service...
Gabriel,
If you are not using other WMS servers as input to your MapServer you should
not have any problems using a GDAL built without gif support.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
